Have TMS lowering springs which lowered the car 30mm and have fitted 18" alloys with 225/40/18 low profile tyres but looking at the car it seems like it could be lowered even more would this be possible??? :thumbsup:
Yes, it would with different springs.
Hello what make of lowering springs can i use to go 40-50mm lower have you any idea, then i can change the TMS lowering springs :thumbsup:
Well, I believe TMS springs are Eibach so you can go for the Eibach but it doesn't matter really as long as it's a well known brand. You can find the spring you want at almost every brand out there.
But if you go lower than 30mm, probably you also need to change your shock absorbers too.
Also click here, someone ordered 40mm springs from Japan. You could ask him about the details.
