St185 Straight Intake Problem
gezmeister
I bought a straight intake and i'm having trouble fitting it to my st185. I have a baileys dv30 recirculating dump valve and want to add this to the circuit but the car won't start now. Any ideas?
My setup is this:
Dump valve - Straight Intake
Straight intake - pipe nearest turbo underneath i/c
Pipe furthest from turbo underneath i/c - breather filter
I know that the pipes underneath the i/c are idle up and pcv iirc. But unsure which way round these are. Could my problem lie here? Or do i need a straight intake with 3 outlets?
Regards
George
could you possibly post a pic? even if it's one from a camera phone or something as i don't really get your set up.
straight intake should be :-filter,AFM,straight intake, turbo.
if you have a re-circ dump valve then it should just be tapped in after the AFM.
or is it the vac lines your having trouble with?
