Should I Buy A New Toyota After This
tezread
I have an 55 plate Corolla MMT Diesel that has had the following happen since I bougfht it in October
Alternator replacement
Front brake pads
Clutch actuator and Multimode transmission problems
Rear brake pads
Window seal replacement
Has Toyota quality reduced somewhat over the last few years or is it an isolated case
Do you think this is too many problems to warrant me getting an Auris or is this normal for a Toyota?
What is the difference in the Auris to a Corolla other than looks?
Sounds like you got a bad 'un there.
There will always be the occasional car that has problem after problem but generally speaking Toyota's are usually quite reliable and problem free.
If theses problems have been highlighted then does that mean they will be ironed out in the Auris? How long does it take for service departments to id problems and have manufacturer lines make alterations?
I love my car i know a lot worse can happen but i do feel toyota is dropped slightly in smaller parts, not major problems but the small little things which dont last.
My studs breaking,
My brakes continually wearing out
Occasional noises from back suspension
when you sit in the car it creaks.
HAS SOME REFINEMENT ISSUES.
Im actually really down about the car at the moment to many problems ....
but if im honest id either change to a compressor because i love em.
or not buy a toyota after probably when insurance isnt such a problem a bmw or something.
My studs breaking,
I have this creaking noise also when getting in and out of my car, took it to Toyota and it turns out it is the handbrake that is making that noise!
handbrake....THATS WELL ANNOYING THAT SOUND....EVERYTIME SOMEONE GETS IN IT MAKES THAT NASTY NOISE... I GET ANNOYED WITH SOUNDS LIKE THAT MAKES ME WANA SPRAY WD40 EVERYWEA..
THAT HANDBRAKE ISSUE CANT B RESOLVED...THANK GOD THO IT AINT MY SUSPENSION.. LOLOL
Also have the annoyance of the car squeeking when I get in and out :(
Add that to:
The radio falling out
Squeeky clutch pedal - fixed
Faulty door seals -fixed
Think that's about it for now - not bad though on a car of 60k as all I have had to change is the front tyres twice, backs once and the brake pads all around.
I had a Corolla 54 plate M.M.T Diesel for 12000 miles. It rattled around the gear selector, the m.m.t gearbox had a mind of its own. Jerking, as it slammed into first, a problem solved by sticking it into neutral when coming to a halt. Taking forever to make its mind up whether to select first or second when moving slowly. This left me stranded on a busy junction as cars braked to avoid me. Other numerous niggles from a cracked windsreen on delivery to paint missing on a sill.
My first Toyota so I gave them a second chance and bought my present Corolla 1.6 auto. Great car, nothing to complain about.
Now thinking about an Auris. However, on reading the owners forum, all is not well with the model. Noisy brakes, rattles, screen washer etc and well,well, the M.M.T gearbox is a major problem area.
I think Toyota are losing their way.
yep.. ive got a 2002 T3 n gutted to say ive had a few problems with mine too:
first off .. the squeeqing noise when getting in and out the car i get that also.. its deffo my hand break though i know that for sure its nackered!
then i had a ringing noise coming from the manifold or somthin when ever i reved the engine sounded nasty..
my windows have stopped working either somthings jammed or motors have gone .. need to ge tthat checked out.
washer jet motors gone..
gears where not slotting in properly it was not going into third gear.. had to get that sorted..
had problems with break pads..
come to think about it i love the car but it hasnt really been all that good to me!! lol
