Loss Of Power
lose power when car is warm, the power loss occours then the dash lights up with the engine light and the traction control light comes on! idles poorly and when comin to a stop at light s it cuts out . when car is restarted it runs fine for a min or so but same happens again any idea?? if i plug outthe airflow meter it idles fine but wont drive!! plug it back in again again an the engine stutters an cuts out!! any ideas its really annoyin me. oh the dump valve is the standard one with the recirc pipe pointed up for the whoosh!! put it back as factory but still the same.
help
First thing is to check for error codes m8, there is a how to somehwere on here but can't remember where.
anyone know the where abouts??????.....
Failing that i think this is how it goes.. you short pins Te1 and E1 with a piece of wire/paper clip or something similar,iirc in the diagnostic socket in the engine bay, then turn ingnition on to position 2 the eng light will flash in sequence ie, 2 flashes ..pause 3 flashes, denotes error 23. get me?..
anyhoo HTH.
Mo
anyhoo HTH.
Mo
il give that a go so c wat i can make of it jus fitted a intake pipe onto the turbo off the air filter box was in half , have one prob about the stalling sorted lol.
sound for the info lad
