Curren St206 3s-ge Water Temp Off The Scale!
fritzkrackers
hi,
my curren st206 with 3sge engine water temp guage went off the scale before i noticed it getting too high. the heater has stopped passing warm air too.
i checked the coolant level and found it below the minimum indicator. the car is regularly used and this fault occured very quickly.
i topped up the coolant, restarted the car and held engine rpm at 3k. the engine temp rose again to a stupid level and the radiator fan did not kick in. i also heard a faint whine from the area below the alternator.
i suspect the water pump has packed in but would like advice. it may be worthy to note the coolant has never been changed in 7 years and 66k miles of ownership.
dont worry... im ok... just save the car.... cough
fritz
I'd look into changing the thermostat. If that doesn't work then start thinking about the pump.
I'm not saying i'm a pro, but thats what i'd do.
Hope this helps
