Help
Blackberry
High emissions. Autodiagnos is showing that there is an emissions related fault but no fault codes present. Garage have checked the fuel pressure and air pressure - ok. Injectors have been checked and are at top of tolerance range but ok just.
Car is showing high CO2 and high hydro carbons (4.6). He has carried out all checks detailed on Autodata and everything appears to be ok. Lambda is switching as it should at idle but not at 2500rpm. It has recently had genuine lambda fitted
Need to know what to check next please.
Regards,
Blackberry
