Radio Failure Of Fm Sytem
mms
I have a yaris 1.3 2000. It has just been serviced and the FM part of the radio is now locked on to one channel and will not tune, the AM part of the radio is still fine.
Has anyone any suggestions please
MMS
MMS
scour the forum as I remember reading about things like this happening. Also, try disconnecting the Battery, leaving it for about 5-10 mins and reconnecting it.
This sometimes helps over-ride niggles like this.
MMS
If you have no luck, I would suggest a used replacement as they are getting common now in the breakers or on eBay and Toyota will charge a fortune to fix or replace a broken one.
They are not too difficult to swap, just time consuming.
MMS
MMS
