Changing Rear Light Bulbs Gen 5 Celica 2.0gti16v
Gen5_2LitreGT_Celica
Hello, I am a newbie here and I can only find one screw on the top to remove the rear right cluster OR is there another way to get at the indicator bulbs ?
Please help me out here, one step at a time, this is my first Jap racer and things are done a little different to what I am used to !!
PS , just had a powerflow exhaust fitted, but now I find that we needed the rubber bushed solid mounting to connect at the front of the new mid section.
The New Powerflow exhaust is just too free to move about hanging off just the rubber doughnuts whilst driving on rough roads or from cold start.
PS I am from the United Kingdom , so I need somewhere here to get a new one because my original was a bit perished. We will get that fitted and weld a bracket
to the powerflow exhaust as per the standard to achieve a bit more rigidity in the whole system !!
Cheers, I look forward to your reply !! J
FORGET IT PEOPLE I HAVE JUST GOT THE ANSWER FROM ELSEWHERE BYEEEE !! Here is the info to help someone out !!
rear lights: Don't forget the golden rule. Prise the little plastic vents off
with care or you end up with to pieces. The retaining clip is dead
centre on the rear lamp side. A little gentle levering will pop it off
Put a piece of card against the rear lamp if you are worried about
marking your rear lamps.
prize gently from the middle of the rear flat side of the vent,
they can break all too easily, there are 2 screws in there and with the one on the top of the lamp ...youre done !!
side ind: forward toward front end . Held in by a clip on the rear vertical edge
