Someone Must Have Changed A Rear Indicator Bulb ?!
Gen5_2LitreGT_Celica
how do you change the rear indicator bulb ???????
GO TO ANOTHER FORUM WHERE YOU GET AN ANSWER !!
Here it is for someone to make use of just like me, byeeeeeeeeeeeeeee !!
rear lights: Don't forget the golden rule. Prise the little plastic vents off
with care or you end up with to pieces. The retaining clip is dead
centre on the rear lamp side. A little gentle levering will pop it off
Put a piece of card against the rear lamp if you are worried about
marking your rear lamps.
prize gently from the middle of the rear flat side of the vent,
they can break all too easily, there are 2 screws in there and with the one on the top of the lamp ...youre done !!
side ind: forward toward front end . Held in by a clip on the rear vertical edge
