Uk 6th Gen Gt - Abs Standard Or Not ?
Sump
As per title, does the pre facelift UK 6th Gen GT come with ABS as standard? - Is there any way I check on my car?
Thanks.
Sure there is Sump. Get in your car and drive to your nearest Toyota garage... somewhere on the way break as hard as you can. If the wheels fail to lock than it's likely you've got ABS or amazing traction; however if you find yourself staring up at a hospital celing wondering where you are... then you aint got ABS. ;)
I think it is standard though :D
Presumably if you have ABS, there'll be an ABS light on the dashboard that comes on when you turn the ignition on and goes off again after a few seconds.
the abs pump fitted near to the drivers side front under the bonnet gives it away . :rolleyes:
