Apexi Slight Flat Spot
petrolhead
just fitted the apexi sound great it has good mid range power but at bottom end low rpm slight flat spot is felt at the moment it is on the normal air filter box running through the normal black rubber pipe if when it is relocated to behind headlight will this help or do all induction kits pull too much air ??????????????????
^ Not sure I get the photo...
EDIT: Seen the TS in the car park!
My Blitz has a slight flat spot at the low end of the rev range too. Just means you need to give it more beans! LOL.
You say its attatched to the normal airbox?
If its been fitted correctly, checked that all the hosing is nice and tight then there shouldn't really be no problem. Reset the ECU for a bit by either pulling the fuse or disconnecting the Battery for 10 minutes, then take the car for a drive and that may make a difference.
