I get a whistling wind noise around the driver's window when going at 65 to 70 mph which is quite annoying.
Is this usual in the Aygo or has mine got a problem?
Any help would be appreciated.
nah its not usual. get it seen to.
check the rubber around the door to make sure its not folded into itself and is properly around the edges of the door. You can pull it straight off to check it.
Poss wing mirror, try putting your hand over the mirror when it whistles. If it stops that will be it.
Will be covered by warranty anyway :).
Mart.
I had that. Bloomin' annoying.
Got the mirror changed, and it was alot better. Still whistles slightly on some days though. If I fiddle with the seal it goes again.
Prob was the gap between the coloured bit and the black bit on top of mirror. Some have a bigger gap which makes the noise.
Ian.
