just picked up my 6 month old aygo the other day.
Ive noticed that the clutch pedal sometimes seems to feel like it is sticking on the way back up when you change gear/depress the pedal and lift off.
as you lift your foot the pedal seems slow to react/stuck, leading to overevving of the engine and some horrendous take off noises.
dodgy spring?
needs lubricated?
ikduncan - I can't really help you with this particular query - but am sure there are some people on this board who will be able to help you out.
I dont know either, best take to Mr T as it will be under warrenty still
SJx
Try a bit of WD40 :thumbsup:
Or if you have none, lard is usually quite good!
I had the same problem found out it was the mat getting stuck on the pedal.
Same as Trev.
It was the rubber floor mat out of position and the pedal was catching on the edge when fully depressed.
