Replacement Wiper Blades
Braxton Hicks
One criticism of the wipers on our Verso is that when they 'sweep' one way, they clear the glass - only to drag a pile of crud back across the glass on the way back down. B)
I did the usual (clean the blades by running vinegar soaked sheet of kitchen roll along both edges of the blades) which had a limited effect.
Looking around a well known auction site (beginning with E and ending in Y) I typed in:
Toyota Corolla Verso 01-06 AERO VU FLAT Wiper Blades
They cost £13.85 for the pair - inc delivery - from a place called 'aceparts'. One is 16"/400mm and the other is 26"/650mm.
I can confirm that they are very good and do work! Delivery about 7-10 days from Guernsey.
Took all of 30 seconds to fit, more importantly... no crud, improved visability excellent quality & worth the money!
