Rear Tail Light Not Working
tczwoju
I have a problem with my rear tail light(Avensisi 03,T4,Automatic).It does not work.I have change a bulb but still no light.So I have check a voltage when it is on and nothing there.Should it be something around 12 Volts?.What about a fuse is it possible that the fuse has blown only for this light.
Any idea?
Cheers
Wojciech
look for a fuse named TAIL. youre owners manual will tell you where its located. im not sure where that fuse is located in righthand driven cars. :D
Hey,
I have forgot to say that I did sort it out just after it happened.It was very odd because other light had a broken bulb as well and that was a source of problem.After when I did change both bulbs ,it is ok.
Many Thanks
Wojciech
