Changing Headlights
pkny247
Hi
This may be a bit of silly question but how do you change the main headlights on the TS??
(I dont have my manual on me)
It looks like i need to remove the Battery first? is this the only way??
It can be done .................but you will need agile fingers and be prepared to skin your knuckles......................good luck :thumbsup:
remove the Battery to make it easy but there is enough room unless you've got sausage fingers- you cant just undo the headlight screws and pull the light forward as you can on a lot of cars as the front bumper is in the way. had a couple of headlights changed under warranty and they tried once to cheat the light in and out without removing the bumper but the light wouldnt line back up so the bumper come of anyway
