Undrestanding Toyota Chassis Number
toos Khodro
Hello,
JZX90-6514013 and JZX90-6534155
They are Toyota chassis number.
Could anyone help me that this two chassis No. refers to what Model of Toyota?
Take a look here...
:thumbsup:
How to read a VIN
1st character - Identifies the country in which the vehicle was manufactured. For example: U.S.A.(1or 4), Canada(2), Mexico(3), Japan(J), Korea(K), England(S), Germany(W), Italy(Z)
2nd character- Identifies the manufacturer. For example;
Ford(F), Nissan(N), Toyota(T), VW(V), Volvo(V).
3rd character - Identifies vehicle type or manufacturing division, D = Passenger Car
4th to 8th characters - VDS - Vehicle Descriptor Section. These 5 characters occupy positions 4 through 8 of the VIN and may be used by the manufacturer to identify attributes of the vehicle. Identifies vehicle features such as body style, engine type, model, series, etc.
9th Character - The check digit "character or digit 9" in the sequence of a vehicle identification number (VIN) built beginning with model year 1981 (when the 17 character digit format was established) can best be described as identifying the VIN accuracy.
10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994®, 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
11th character- Identifies the assembly plant for the vehicle.
12th to 17th characters- VIS - Vehicle Identifier Section. The last 8 characters of the VIN are used for the identification a of specific vehicle. The last four characters shall always be numeric. Identifies the sequence of the vehicle for production as it rolled off the manufacturers assembly line.
That should be pinned topic for future reference.
Having said that, I can't quite figure mine out.
JTILOAE9207097587
So
J = Japan
T = Toyota
I = ? It is a Corolla 16 valve Executive GL Lift back ( or should that be read as ILO ?)
AE92 = identifier ?
O = 10th character, but it is 91 reg
7097587 = it was the 7097587th off the line
Sorry if I am being a bit stupid, but can't quite figure it to my satisfaction. I have checked the numbers in my log book 3 times !
dont think TVORs info is quite accurate. burnaston built cars start SB1, S is UK but B=Burnatson?. on the whole its nearly right tho.
J = Japan
T = Toyota
I = ? It is a Corolla 16 valve Executive GL Lift back ( or should that be read as ILO ?) AE92 = identifier ?
The 3rd number is for vehicle type, yours could be a 1 not an I meaning a passenger car.
D, G, K, X, 1, 2, 7, N - Passenger Car
A, B, M, 4 - Truck
B - Truck
E, L, 3 - Multipurpose Passenger Vehicle (SUV)
5 - Incomplete Vehicle (typically a convertible)
So far...
JTILOAE9207097587
JTI – Japan Toyota Car
LOAE9 – Body engine model series
2 - Is the VIN Check Digit Manufacturer's Internal Code
0 - Model year Check Manufacturer's Code
7 – Assembly plant
0 - 9 - 7587 - Sequence of the vehicle for production as it rolled off the manufacturers assembly line, yours was the 7587th
:thumbsup:
J = Japan
T = Toyota
A, B, M, 4 - Truck
B - Truck
So far...
JTILOAE9207097587
7 – Assembly plant
:thumbsup:
Thanks, mate :clap:
  • 3 years later...
Can you tell me what this code means?
SB1KZ20E50F063957
S for england but what stands the B for? BMW?
  • 2 years later...
Thank you. Do you have full decoding list for each block? In the post you linked it is only vaguely described.
  • 2 years later...
Old thread but the original poster was referring to chassis numbers not VIN numbers. Some early model toyota's have a 5 digit model number (2 letters followed by three numbers) followed by 7 digits stamped into the chassis. For example mine is LN130-0023003. Anyone have a resource for decoding the meaning of these? I'm extra curious as the vehicle is a 1989, witch was the first model year for the first generation of Hilux Surf and these all seem like low numbers. Would be neat to know what number off the line it was :)
  • 5 years later...
Model : DBA-NSP130-AHXNB
Engine : 1NR-EKE
FRAME NUMBER  : NSP130-2213913
1329 ML
K411 - 02A
Can i get the manufacture year ?
