Slight Problem After Changing Bulbs In Headlights
Hi, I changed the bulbs in my front headlights, and they work perfectly (eg. dipped, full beam etc). But I cant control the headlight beam level, u know the wee rotational button beside the handbrake in the 98 corolla, and when u increase the number the lower the headlight beam level...
But when i change the number, nothing happens to the headlights....please help! :o
The bulb fitting/bulb shape isnt fouling on the reflection screen/silvery bit. that the lights poke through is it?
I have the same in my Paseo & it's never worked.
The bulb fitting isnt fouling on the reflection screen/silvery bit. that the lights poke through is it?
I dont think it is, the new bulbs are H4 just like the standard ones, and they fitted perfectly, I have 2 corollas, and I am going to change the bulbs in my other corolla today and going to see if the beam level control doesnt work in it...
But i just checked the manual, and they say to go to the toyota dealer to get the aiming adjustment done....
Have you gone to the toyota dealer to check it out?
I just changed the bulbs in my other corolla, and the beam level control works perfectly in it! Can anyone tell me what could be wrong?
You might have blown a fuse for the Headlight level control when you changed the bulbs.
Did the Level control work before you changed the bulbs ??
I was thinking the same mick, but u see i am not sure if they did work before!, they did work several weeks before, but its not often u use the beam level control!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
