hi all again. i fitted 1.5" body lift. easyily fitted. im looking for info . i want to lift the suspension now. 2 or 3 inch kit. can i buy a kit or best to buy stuff individually. what am i looking for. ? any help // cheers
If your only going for a 2 inch lift you will be ok with rear springs and then wind the torsion bars up a bit, anything over 2 inches will need ball joint spacers on the front.
Best bet is to ask the guys on the Hiluxsurf forum.
I fitted a 4" trailmaster kit to my old J reg surf and and it still drove great after :D ....Fitted a 4" pro comp kit to my wrangler and ruined my jeep cos the ride was so hard! :angry:
just bought a 2inch lift kit from roughtrax. is it easy enough to remove the standard shock etc? and just tie up the hard soft wires> or do a ineed any special fitting kits or adapters for the shock tops> cheers. watty
