Baileys Exhaust
damogt4
just seen a baileys jasma exhaust system in local paper for sale do day cause turbo creep its for st205
depends how big it is, if its 3" right through then probably yes
2.75 is said to be the best diameter to prevent boost creep. 3 inch systems usually do cause creep.
thougt so.Ledgt4 you wer saying you will be doin all ur fig8 soon found a place in ashbourne called jap parts they have them 120 euro original toyota parts
if your lookin for cheaper gt4 original parts try this place www.tcbparts.co.uk
btw whats turbo creep???
Anyone got a picture of exhaust system I can use to locate the CAT. Want to put a downpipe but a bit unsure of where to find the converter.
is 'jasma' not the jap noise regulations to say the exhaust is quiet enough for road use?
turbo creep or boost creep is the boost levels raising as the engine speed increases, toyota use a little back pressure to keep boost levels under control
120euro? What does that work out at? 80 quid or so? Have I got that wrong cause that aint cheap. They are being sold on eBay all the time for about 60 quid. Did u price the lower arm too? Most people replace both when the fig 8 is being done. yea tcb parts are good
The converter? For the exhaust? Are you talking about the cat? Mate its easy to see the cat. Its that big thing just under the turbo. should be to the left hand side of the turbo, well it is in the st205 not sure on 185, never owned 1.
