Is This The Original Engine? Where To Find The Engine Number?
Africa
Hello,
I bought a used Toyota Celica and would like to know if the engine is original, in the chassis it says is a 3S-GE, i have took some photos, where can i see the engine number?
Here are the photos
it is on the engine block under the distributor, its quite hard to see with the engine in the car so you may need to use a torch and a mirror
Thanks, i already found it... it matches the documents of the car, but i saw a picture of a engine that looks very similar to mine and it says it's a SS-I and my car is a E-ST-202 BLMVF and that matches the SS-II model, so is my engine a SS-I or SS-II?
hi,
the engine in the picture is a 3s-fe not a 3s-ge
hi,
So the previous owner changed the engine to a weaker one right?
The engine number is the same that is registered in the documents of the car, i just want to make sure that i don't get any trouble with the police, i'm not worried about engine power.
hi,
thats correct the 3s-fe is about 125 bhp whereas the 3s-ge is 180 bhp
