Door Cards
Tobin
says its all in the topic title really, how dya take the door cards off, wat dya have2 unscrew etc?
need to no cos my drivers side window wont go all the way down :unsure: and need to av a look y!
***UPDATE***
Afta i thought the ball of maskin tape was stoppin the window goin all the way down, the problem has started again tho.
Any ideas?
Theres a screw behind the door handle, then carefully start prising from the bottom an you will hear the studs popping out.
once they're out all along the sides, push it upwards from the bottom and it should come off quite easy.
The bugger is putting them back on!!!!!!!!!!!!!!!!
HI, CHEERS FOR THAT. I FORGOT 2 MENTION THAT I HAVE A 2004 FACELIFT MODEL, DOES THAT MAKE ANY DIFFERENCE?
Should not metter..
Just thought id let u no, i got the doorcard off dead easy, as i took it off, a screwed up ball of maskin tape fell out.
didnt think nethin of it until i tried the window n it went all d way down. v.strange!
cheers for ur advise guys. mite get sum new Speakers now i no how easy it is. any recommendations?
