Overheating/no Hot Heat/how To Bleed Rad
terance
Hi every one need help on my toyota avensis 2.0 t spirit petrol vvti. (2003. 110000 miles)
my car over heated was lossing pressure in the cooling system, so decided to put in kalmex (k seal) seemed to solve the overheating problem but cant seem to get hot heat inside,(did change the thermostat before puting in k seal.)
any sugestions would be appreciated.
thanx
thanx
Prob clogged the heater matrix behind the dash with the sealing stuff, on some cars thats a dash out job, big bucks. Not sure what the story is with the avensis.
I dont think your supposed to run the heating when your putting that stuff in, have it off and set to cold or something.
Not cheap to buy a maxtrix from toyota, i think i was quoted 300+ euro for one, labour on top then to fit it.
