Another Newbie Says "hi"
Mr E
As the, so far, proud owner of a Corolla 4WD estate I thought it maybe best to join the forum. I'll be fumbling around for a while as this is all a bit new, but by the amount of infomation being passed around it looks like it'll be worth it.
Welcome.
That's an interesting vehicle.
Yes, I think you'll srtuggle to get a manual for it.
Do you know what engine it's running or what else the running gear is used on? For some models you tend to find that there are other cars that share the components for which you can get a manual, then you end up using the appropriate one depending on which part of the car you're working on.
