Abs Light Help
fanboy
Hello all supra owners.
Brand new to this whole thing so excuse if this has been asked before =p
Took my '94 Super to the garage for its wof check, got it back saying the back tyres were too low, and the ABS light didn't light up on startup check. Or whatever you call it.
Changing the tyres was easy, but one silly question i need answered is: where exactly IS the ABS light? I don't think its on the left side of the "cockpit" and nothing lights up over the right, and it surely cant be the big "!" in the centre can it?
I've looked all over the net to find pictures, and found nothing! I don't want to have to buy the haynes manual, theyre expensive =(
Big ups to whoever can help me!
Yup they do this.... I have had one fail on this too.
Assuming you HAVE ABS from memory its on the right hand side of the instrument cluster, just take it apart, check everything is tight, the connections are good and earthed, should work then! failing that it could be the bulb, but thats unlikely as they rarely get any use!
