Ticking Noise Fom Brakes And Throbbing Noise From Back.
peterc.lewis@blueyonder.co.uk
I've got just two little niggles left on my car , does anyone have any ideas ?
The first is a brief clicking sound when braking, it almost sounds as if something is sticking and freeing itself. No adverse effect on brakes and apart from a little squel now and then not a problem. Brakes are new pads on front . The rear drums are still around 3-4mm .
The second is a throbbing noise coming from the back of the car that increases in frequency with speed. There is no noticable difference when going round corners. It's just a constant throbbing noise.
Car is a 1.8 GS estate non-vvti avensis. 1998.
Cheers.
Cheers.
I had a simiar throbbing noise - it turned out to be an unevenly worn N/S/R tyre.
Ian 2005 Av. 2.0 D4D T-Spirit
The noise on the front will probably be the slider pins on the caliper support brackets. These need to be removed and lubricated. Use black lithium grease. (or 'CV' grease - sold by Halfords - branded by Comma)
This link shows the standard set-up. (diferent Toyota but same principle);
http://www.mr2turbo.info/pics/frontbrake.html
The sixth photo shows the pins removed. The caliper 'floats' on the pins which allow for pad/disc wear.
The rear is a different story.
I would agree with the tyres theory. That said the wheel bearing may be worn. They sometimes begin to 'humm' before there is any noticeable lateral wear. I would have expected to have heard some grind/scraping on cornering tho. I would take the car out onto a supermarket car park and drive in tight circle left and right to isolate the sound. Take someone along to listen from outside the car.
