Engine Wont Start - Reset Ecu Fixes It
yarrascar
My Yaris if not being driven for a 4 or more days will not start when I try to start it. Engine ticks over and it sounds like it is firing but as soon I release the key the engine stops. If I remove the ECU fuse for 30 seconds and then re-insert it the card starts fine. Toyota do not know what is wrong. What can I do to stop this problem ?
Apart from the other reply you have had, I would suggest you try another dealer as it is a bit strange if they cannot find a fault. It sounds like a fault with the immobiliser circuitry. :unsure:
BTW, you havn't mentioned the model/age of the vehicle as that may be relevant.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
