Funny Idle And Broken Rads
hi guys ive got a 1996 carina gs e. Only bought the car 2 weeks ago and everything perfect until last weekend,when on the way home car became a right pain. car idles too fast when cold,and will barely idle at all when hot.Anyway,got car home and found a great big hole in the radiator which ive just ordered off e-bay,so im not too worried about that,its more the idle that is annoying me.Ive heard that theres a sensor on the throttle to keep the car idleing at correct rpm.Can anyone verify this for me?also very slight rattle coming from under bonnet.At first i thought the car wasn`t running all the valves.I`d be greatful for anyones input.cheers. p.s. it`s a 1.8 manual.
These faults will probably be related. The idle mixture is affected by a coolant temp sensor. This will not have been fed the correct info if the coolant level was low due to the hole in the radiator.
thanks for letting me know,the new rad is going on tomorrow,and i dont want to use the car until sorted incase i cook the gasket,had a clio before this with head gone and had a complete gutsfull of that. :thumbsup:
fitted the rad last night idle has been sorted but still using lot of water.possible water pump?
