Car Stereo Replacement
Hi there-i'm hoping someone out there might be able to help me.
I have a Carina E, and have just got myself a new Sony CDX-GT441IP Stereo. I have managed to remove the original stereo, and fix the cage, actually, secure the whole unit. The only trouble i'm having is wiring it up!
I'm not too hot on the wiring front, but would like to do it with a bit of help, before i go out and pay for an expert to do it, if its easy!
I hope you can help!
Kindest Regards,
Rich
im looking to do this as well mate so ill be keeping an eye for this.Was it easy to remove the original,and can you give me any pointers for it aka if the full plate has to come off.cheers
Visit the Autoleads site and see if they have a wiring adapter for your car. If they do it'll be much easier, and produce a much better job than splicing the loom. Most professional installers would buy the conversion lead rather than spend hours trying to match wires to your DIN connectors.
If they don't list one then I'd look to see whether any other Toyota adapters will do the job. That may be tricky, but it'll still
Remove the original stereo, and unplug that stereo from the cars cables, then on the cars cables you attache a adapter like this: http://www.biltema.se/Archive/ProductCat/bil/ISO_l.jpg
In sweden it works fine with this adapter, dont know if it looks different where you are.
I had the exact same problem, i got mine from my local Toyota dealership - i gave 150 kr for it, approx £15 ... plug it in the original Toyota and in your Sony HU :)
Kindest Regards,
Rich
I bought an ISO adaptor for mine, then discovered it didn't need it. Chap on eBay has them for about £1.50, so it's barely worth offering you mine.
Greetings fellow Carina Owners. This be my first post on the forum.
I too have (for obvious reasons) exchanged the radio for a decent CD-player. With pliers and
no patience I didnt get an ISO plug, but rather cut the wires and fastened them on the correct
places on the cables from the new CD-player.
Its not as bad as it looks. There are two cables for each loudspeaker, four for the front set and
four for the rear ones. Other than that its ground and 12V plus. However, there are several plus
cables. One allways has power coming to it, so your player doesnt forget things like time, date
and radio station settings. Another gets power when your key is set to ACC or ON, so that you
may start the CD-player. If you put theese two together, you'll be able to play without having
the keys stuck in, for instance. Also, there is a third and last +12V cable, sending signal when
you turn your lights on. This dims the lights on the player (optional, many cd-players dont support
this and ignore the signal.)
In addition to this, there is a cable called "remote" sending a 12V signal only when the CD-player
is turned on, so that eventual power amplifiers other than the CD-player are on when you're playing
music, and off when you're not, preventing them from draining the batterys power when the car
is standing around.
Ive also changed the original wires and front set Speakers. On my 93 Carina E XLI the maximum size
for front set Speakers is 5.25". The ones the !Removed! put in there in 93 really, really should be interchanged.
Feel free to ask me about car stereo, there is much aggrevation to be saved.
Regards
Neuroner
You all want...
Head Unit Adaptor
and when that item expires Click Here and choose the one for your car.
Hope this is useful
Collin
being ur in the uk the easiest way is to walk into Halfords and they will sell you the iso wiring kit for your car.
But you can save £10 looking at my links
Kindest Regards,
Rich
Update: Managed to connect the stereo, it works, sounds good.One minor problem: It doesnt remember my pre-set radio stations or the time! Any ideas on what this might be, have jus about tried everything i can think of, help!!
Kindest regards,
Rich
Kindest Regards,
Rich
Kindest regards,
Rich
Hiya, some leads have the 'permenent' and 'switched' lives the wrong way round, have you checked this in your plug? It could be the problem as mine was the same and after swapping them over it has been perrrrrrrrfect.
