Removal Passenger Door Trim
heysidays
Was wondering if anyone has any photos/instructions/ideas on how to remove the passenger door trim, i have an annoying rattle coming from this area that i would like to try and cure myself. Being a novice at removing trim I thought it be wise to ask the question on the relevant forum. Tried the dealer and they haven't cured it, it is a rav4 07 plate.
Rattles - they are a right pain in the ****. :(
Can also be quite difficult to find a lot of the time. :yes:
Have you checked out Anchorman's rattling mirror fix here:?
http://toyotaownersclub.com/forums/index.php?showtopic=71928
Might be worth checking that it is not that first, assuming you haven't already.
If you still want to take the door trim off, PM me an email address and I can send you a pdf. I expect Anchorman will do the same if I'm not around.
Cheers
I have a rattle that comes from the switchgear in the drivers door so that is worth checking in the passenger door. I will get around to is soon but if it starts now I just rest my knee on it!
