3 Questions In One!
Notebook
55 plate xtr petrol - belt or chain?
Sun blind you place in the window when out of the car - whats the correct name? - do toyota sell one?
Pre washing my car I wanted to know if I could wet it with car wash from a hand pump pressurised bottle - like you spray weeds with. I pressure washer, but where I live at present would mean running it all through the house. So wondered if I could wet it with the spray and then rinse it off before washing it with a mit... just a thought as I ahvent any idea how much pressure they have.
Phew
Chain - no replacement ever needed in service schedule I believe
No Idea
You can get upto about 4 bar on those garden sprayers. Not sure how much water you can get out before you have to pump up the pressure again
No Idea
fantastic answer - just that the answer
too many places you get advice you dont need
thanks
Just be careful on the water pressure as you can damage seals.
On the sun visor, have you tried these things they get for sheltering babies from the sun in cars??
And not just seals! I knocked a bit of paint off when I was trying to shift some birds**t off the wifes Punto with a power pressure washer :wacko:
Do you mean these type of Sun Blinds...
Most are made of Aluminium foil type material and reflect the heat...Just need to pick an appropriate one... :rolleyes: :rolleyes: :rolleyes:
Toyota may sell them....but most motor parts places will....
Toyota dont do a sun blind, but most motoring outlets would do something similar
Kingo :thumbsup:
