i have a toyota privia 2.4 auto which when driving i have a strong smell of petrol...but cannot find any visable leaks anywhere through petrol system...would any body help or be able to answer my problem...many thanks.
grandadpops
grandadpops
I had a problem like this on my Previa, it was corroded breather pipe on the filler neck. Could not be seen without removing the wheel arch liner on the fuel pipe. I repaired mine by making up pipes out of copper & fuel hose, I think the filler pipe is an expensive part. Check this or other joints under plastic covers
grandadpops
If it is the filler pipe & you want to get a new one the part No: is 77201 as in the Toyota EPC
