Brake Squeal
lomander
Hiya folks
Can anyone help with this one just bought my 52 plate T sport 2 weeks ago and now my back and front brake's are making a terrible squeaking noise. My pal stripped my front brakes down and copper greased them and all was fine for a day or two and the pads look near new but once again the annoying squeak is back! Any suggestions
cheers
ck
mmm... change the pads? maybe they are worn on the backing and moving around. if they are the OE pads, they squeak when they get a bit older, i found blitzing them with a karcher helps.
Hiya folks
cheers
ck
do your mate remove the sliders from the boots or did he just grease the bolts? i remove the sliders from the boots and clean them followed by a buff with a fine wire brush attachment on a drill. i also remove the boots and clean and grease where the sliders sit. when you say they were fine for a couple of days it leads me to think they werent cleaned/greased correctly or the copper grease was low quality - i am presuming its constant and not just when you apply the brakes?
mike
Hi mike
No its constant when you press the brake it stops. This is when i wish i was more mechanically minded will book car into my local garage!
cheers for the help guys :thumbsup:
ck
Hi mike
ck
its just the brakes binding - you may have warped the disc from the excess heat that builds up. you dont need to be mechanically minded to clean/regrease caliper sliders. you'll probably do a better job as well. buy a manual and give it a go? jack the front of the car up and spin the wheel - if it only catches on one point of the rotation the discs are warped.
mike
By they way...
Does anybody knows which is the Brembo part # in order to replace the discs/rotors of the Corolla Tsport?
I'm thinking of switching from Toyota discs to Brembo. :rolleyes:
Thanks for your help.... :toast:
Cheers!
Hi I also get terrible break squel but only when i apply the breaks and when the cars just about to stop!
