Corolla Gti Knock Sensor Faulty
maxsGTI
i had a guy from the local diagnostic garage come and check my corolla gti out, ive been told its a faulty knock sensor code 52, where can i locate that on the engine?? also any ideas to how much this may cost??
cheers
should be on the back of the block.about 27mm hex and a single wire connection
hi, i had a good look couldnt seem to locate the knock sensor, any chance of any picture of the sensor also and pic of the engine block to point out where abouts i should be looking? i went into Toyota main dealers for the knock sensor, they wanted £130 for it!! is that expensive or is that how much they cost?
rang around afew toyota breakers yards, they didnt seem to have a clue where they knock sensor is on the engine, help me guys i want to get my corolla gti on the road just this sensor is holding me back now
on the 7a-fe its located under the intake manifold - i think the 4a's will be in the same place. if you cant buy them aftermarket Toyota will charge you a fortune. try taking the plastic connector off and on a couple of times - this often works as its often just a bit of oxidation on the connectors.
im back!!! ok ive had my mechanic check my car for the knock sensor but we didnt locate the knock sensor.
but while we were searching we realised that on the engine block near to the alternator there is a plug which seems to have the the connecting lpug missing, i had a good look around in case it isnt connected but didnt find any spare plugs lose. now im woundering could that be causeing the engine mangement light to come on, also i came across the lamda sensor at the front of the engine to the bottem its missing some sort of plug i belive. is there anyone near to nottingham who has better knowleghe then on these cass come and give me advice? im willing to sort some money out if i can find the fault
cheers also check pistonheads ive put my car up
if you remove the intake manifold you'll see the knock sensor - or if you have access to a ramp its in the middle directly below the inlet manifold. If you are struggling buy a Haynes ;)
The knock sensor looks just like a oil pressure switch or a temperature sensor. It gave up on my MR2 and left the car with less than half the power. When i went looking for the sensor i thought it was a oil pressure switch untill i screwed it out and there is just an empty hole behind it. Its usuall located in the middle of the block from each end and usually on the intake manifold side a couple of inches below the head. A 27 MM spanner fitted it and two minuites changed it.
ok cheers guys il give it a another look during the day, to be honist ive never seen a knock sensor soo im abit confused to what sort of shape or switch im looking out for...ive searched the net to see if i can find any picture to where 100% i should looking at, if you have any pictures to make my life alittle easy then many thanks, but for now thumbs up and i keep you guys updated how far i get.
