How To Set Time Display
kooboy
Hi
I've corolla verso T-spirit. I don't understand how t change the time settings in the odo display.
Couldn't find even in manual. Can somebody help me please.
Cycle through the displays until you reach the 1 you want using the DISP button. To reset the HOUR push and hold DISP until the hour flashes then push the DISP button for each hour step. If no button is pressed for 5 seconds the MINS start to flash now each press of the DISP button will step the MINS. If no button is pressed for 10 seconds the time is set to whatever the display is showing.
Page 245 in my owners manual in the Other Equipment section under Clock.
Hope this helps
