Please Help Info Required
milka
Hello,
New owner of a MR2 Roadster, however I have noticed a Metalic Grating Noise from the clutch what the most likely cause for this and what will it cost me to get it repaired :(
thank in advance,
Is this when your foot is on the clutch or off?
If the former is it like a rough squealing noise? It's possibly the clutch release bearing, though it's difficult to say for sure without hearing it.
Hello,
thank in advance,
How new? do you not have any warranty, or was it a private sale?
Hello,
thank in advance,
When the clutch is on I can hear it, when the clutch is down or in neutral then it goes away,
yes a private buy, is this going to cost me?
update,
Since hearing the noise I was driving along when it became a lot louder and high pitched, Now the rear diff has locked up and I can't select any of the gears.
I think something might have broken off the clutch and jammed itself in the drive train. I have left it with the Garage :( poor mr2 will give update.
£1300 later a rebuilt gearbox and a new clutch, a gearbox bearing had fallen to pieces and lodged its self in some vital moving parts. its all fixed now but that was a bit scary.
