Damn Modding
Corolla Chris
After swearing to myself I wouldnt mod the Compressor I've completely swayed the other way....
So far I've got CAI, Front pillow ball mounts, TRD clutch, C-ONE flywheel and I'm in the process of sourcing big brakes and some gram light rims....my wallets nearly dead but hey.....ho......lets go
Chris
PS also got a GReddy oil sandwich plate for oil temp and pressure!!!
Good lad lol nice to see. What difference does the clutch and lightweight flywheel make?? What gram lights are you goin for
Chris
hi corolla chris was it you that was going to get your gearbox looked into while you were having the clutch and flywheel fitted if so what was the outcome .is the c one flywheel lightened if so any better on pick up
Chris
just wondering wat you were wanting from the big brake kit.. something to fill out the wheel gap or performance.. i personally was looking for performance and found it cheaper buying a good set of slotted rotors, pads and braided lines.. (in aus) i was told that upgradeing the size of your brakes requires engineering and thats expensive here (not to sure on your car regulations).. i do a lot of mountain runs here and my set up works really well also my hd clutch and lightend flywheel work great.. revs drop quicker than standard so i found my short shifter a dream to drive with.. throttle response is awsome in conjunction with the cai.. i found it a great mod.. have u thought about an aftermarket ecu.. just a bit of feed back on my set up hope it helps in future mods
