Corolla E12 Tte Front Spoiler
UKDM323
I got a TTE front spoiler (prefacelift) sent to me now so for those know about it &/or fitted one can you come foward &help me perhap either here or via pm? its nothing bad about it or hope not!lol ok is jst a little bit otherwise i wouldnt be posting about it, :P its something they didnt tell me in the insturctions :rolleyes: the fitting is fine though.
Thanks anyone can help !
Hi there, the TTE front lip is bolted on to the car. if you lie down by the existing black plastic guard that is already on the car and then put your hand behind it and then move upwards you will feel the bolts there. From memory of when I did this, there were 6 or 8 bolts holding it in place. You just need to remove these and the existing guard will come away (in 2 pieces). I never saw the tte lip before it was fitted but I know sometimes they do not come pre-drilled, so if this is the case, then use the existing guard and place it on top of the tte lip and use it as a guide to position the drill holes. Once done just bolt it back on and you have yourself a tte lip fitted.
Hi yeah i test fitted it already but only problem was (is) the bolts located on both ends where you cant really use a straight screw driver unless u put the car on the ramps & go under it but i now know what to do there! everyhting else is fine tho.
thnks
