Replacement Key
davemh
Our R reg Corolla 1.6 has only one key, I need to have a spare / second key & transponder. Anyone used any of these mobile key replacement companies? I understand it can cost two limbs to go to Mr T so I'm looking for a cheaper alternative. Any advice would be appreciated.
Hi i am a mobile auto locksmith and do many toyota keys.
There is a few ways to do it if you have the master the you can just by a blank key with transponder and get it cut and programm it yourself
, or no master key u need to have the ecu re-flashed and new key programmed prices change town to town , or option 3 is to have the key cloned onto an electronic head which the locksmith uses take about 10 mins also prices change from town to town but all will be alot heaper then the main stealer.
HTH
Gary
