Stupid Question
Burger28
Filled up for the first time and pressed the button... but that just switches between Trip and Total mileage... holding it in doesn't seem to do anything... so how do i reset it every time i fill up? :P
woulda said it was about 10secs maybe more i tried.
And I presume you're holding it in when it's on the trip view, not the main odometer?
I would have thought that would have done the trick.
The button obviously works if it toggles the display between the trips and the odo, so unless there's some other instructions in the manual, I think you're going to have to ask Mr T.
i do have the manual i think... thought this might be faster and less hassle :P i think i tried it on trip and total views... i'll make sure tomorrow (if i dont get a definitive answer on here tonight)
i has an T plate avensis, that suddenly wouldnt restet the trip comp, i put it down to the age of car, but it had done 240000 miles
well the trip has only reached 770 miles or something so it's not been broke ages and it's only done just over 82k overall
When it's on the trip display hold the button in for 2 seconds and then let go. Any longer and it doesn't work. There is a bit of a knack to it at first.
thanks dave. i managed it yesterday by accident before i read this post! :)
The reset is automatic: when you are driving away after a refill, it occurs after a short distance.
