Front Brake Discs.advice Please.
peebee50
Hi everyone.
I will shortly be replacing the front discs and pads on my 2002 Corolla.Does anybody know the correct torque settings for the front brake caliper bracket bolts? I am referring to the bolts securing the caliper bracket to the wheel hub. Many thanks.
brake caliper carrier to hub 107nm
brake caliper to carrier 34nm
these are for the front - do you need the rears aswell?
these are the settings for the T Sport - other models may differ.
Thanks very much for the information. I would think that unless the discs fitted to the T Sport are larger than the standard discs (i.e. 255.0 mm Diameter ) then the torque settings would be the same. Do you know the diameter of your discs? (I do not need the rear brake settings thanks).
The T Sports are 275mm. Have a look on the Toyota Tech site - might be on there?
Hi, Similar topic (disc brakes) anyone know what would Mr T charges to replace front and rear to 54 Reg 1600 T3 Corolla.
did you manage to get the settings? most people dont use them - but i'm the same, like to know its right. if you are still struggling i might be down the garage tomorrow so i can get them then for you. or i can PM you a couple of members to try?
Sorry for not replying - haven't checked the posts for a few days ! I wasn't sure how to get on to the Toyota Tech site so I am still not sure of the settings. I know that people don't always use them but I am a bit of a worry-wort when it comes to brakes since they will most likely keep you out of trouble when it matters!
I have found a site where you can download a workshop manual for about £10 but am not sure if it's genuine. What do you think?
http://www.workshopmanuals.biz/toyota_bridge_page.html
