Avensis D4d Problem
Paul1234
I am geting engine vibration at around 60mph
It occurs in both 4th and 5th
Only when the power is on
Can be powered through, no vibration 70+mph
I have the 2 litre D4D diesel
Any thoughts/ ideas welcome
hi
test all four fuel valve idle performance having removed them.
also change fine fuel filter.
cheers/igor
I spray cleaned the MAF widget as suggested elsewhere on the forum which has definitely improved things but the vibration is still there although it seems to have moved up he mileage range and is not as severe
Where do I find the fuel filter, and do the other check you suggest
hi
it is easy to locate fine fuel filter. it looks like a cylinder before HP fuel injection pump.
i had this problem with vibration on my previous car and once tested injectors the problem with vibration has gone.
cheers/igor
hi
cheers/igor
Hi Igor,
Do you know anywhere that details exactly how to carry out the fuel valve tests you mention?
Cheers.
hi
cheers/igor
Hi Igor,
Cheers.
hello mate
sure i know all procedure thanks to i 've got a tesk device in my own garagel.
please just list all you need to know by return.
thanks/igor
  • 4 weeks later...
hi
cheers/igor
Hi Igor,
Cheers.
hello mate
thanks/igor
