Avensis
wahidhussain
hi all you guys i have owned the car for about 1yr&9moths mot is due in aug08 what sort of problems should i look for i would be very greatful if you yuys can help
thanks
wahid hussain
hi all you guys i have owned the car for about 1yr&9moths mot is due in aug08 what sort of problems should i look for i would be very greatful if you guys can help sorry about the spelings
thanks
wahid hussain
should be fine, not many niggles with the avensis. main points are warped brake discs (judder under braking) and worn suspension bushes on the front lower arms, new bushes are about £25 each (2 req) but a complete lower arm can be had from motor factors for about £40+vat and they come with new bushes and a new lower ball joint.
other than that it should sail through.
thanks alot (dawesy) thank you
  • 4 weeks later...
hi guys
i just woundering do mean anti roll bar bushes (dawesy)
thanks :thumbsup::thumbsup:
wahidhussain
