The Rebuild Begins
dawesy
well finally getting somewhere now blocks back, gapped and fitted the rings and installed the new rods so wont be long now.
the new rods do look a tad beefier than the standard ones :P
with the pistons
and a new twin plate clutch too
Ohhhhhh they look sexy......good luck putting it alll together!
Nice!!!! I love this bit ofa build, when you have the main bits and can just get about assembly!
well kinda ground to a halt, came to replace the two valves that had an argument with the now detached piston to find two broken guides. decided to replace the 8 inlet ones as there is a little oil in the intake, it hasnt come from the turbo as the IC pipe work is dry so only place is guides or seals.
gonna be busy next week but hope to get back on it the week after.
tasty looking hardware there dude :)
well got the rotating assembly together.
block awaiting the crank
crank in with ACL race berarings
close up of rod, piston and crank
and some pics of the carnage caused by the failed rod!!
aerated block!!!
£400 worth of scrap JE forged pistons (can you spot which rod failed :) )
and a very battered baffle plate (lives between the crank and sump)
more piccies to come :thumbsup:
