Carina Ii 1,6 Mufflers
Hello!
I've not found any manuals to this, so I thought that you guys might help me.
So, I'm trying to change the front-end muffler to the car. The bending part is the one that is cracked up. I'm not quite sure how should it be done, but atleast there is three bolts in the front-end. And maybe at the end.
So, does anyone have any kind of images/manuals that shows what should be done? And is it possible to change only that bending part for this car?
Well, I took a picture of that bending part and it looks like this.
Has anyone got any clues how that should be fixed? Except changin that muffler...
No - the flexible part cannot be changed alone. You need to buy the front pipe which includes a central box. You will need gaskets at each end.
See:
http://www.bodyshopwarehouse.co.uk/
The on-line catalogue showns the components required.
Actually it can be done. I thought that it could be cut out and replaced with welding. Why shouldn't atleast try it? That comes a lot cheaper than buying the full front-end-muffler.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
