Revs
wahidhussain
hello all toyota lovers one quick question. When the car is warm after about 20minuites the revs seems to go down to about 700rpm is that normol or is there something wrong with the car or is it just me because the car drives perfect it only happens when im only stationary or when im at traffic lights.
I WOULD BE VERYGREATFUL YOU GUYS CAN HELP ME :angry::unsure:
THANK YOU
WAHID HUSSAIN
THANK YOU
WAHID HUSSAIN
hi Wahid
it varies as 700-750 rpm after heating up.
no reazon to be worried
cheers/igor
:thumbsup:
THANK YOU
WAHID HUSSAIN
hi Wahid
cheers/igor
:thumbsup::thumbsup::thumbsup::yahoo::yahoo::yahoo::yahoo::yahoo:
thanks you igor :thumbsup:
wahid hussain
If you switch the air con on you will notice the idle speed go up when the compressor kicks in and then go down again. It is the engine management system working out the best idle speed based on a set of sensor readings.
yes for sure
igor
yes for sure
igor
yes i agree
thanks igor & hertsnminds :thumbsup::thumbsup::thumbsup:
wahid hussain
