2 Gauges For Pillar
Scotty GT4
Hey all was given a pillar for the drivers side with space for 2 gauges. could anyone tell me what two would of best use to me and any links to sites would be great help. thanks
Most would say boost gauge is the most important as the stock one is crap. But I have compared it and couldn't believe how accurate it was. Each division is exactly 2psi up to 10psi max. Never the less I would still get an after market boost gauge as the stock boost is ~13psi.
Secondly I would get oil temp or pressure as these are easy to fit and quite useful. As you have a basic water temp already I'd probably go for oil pressure. I got all my stuff from a shop on eBay called gaugeplace. The guy is really good and I got 3 gauges with all fittings/senders and oil filter sandwich plate for less than £100.
Alternatively you could get a voltage meter as this would be the cheapest and easiest to fit.
