Abs Light In Carina E
Hi, recently my ABS light is on when i'm above 100 km/h (60mph) - my brakes works fine, do any of you know what it might be? I don't wanna take it to the garage and pay loads of money if it is something i can fix myself :)
Regards Jan
Have you checked the brake-fluids? It just might need a little more fluid.
It doesn't seem to be needing some, but i'll try to fill in a little more :)
Hey, i tried to look, but it is just above max - so it doesn't seem to be the braking fluid =/
  • 6 months later...
Hi i had the issue but mine was on all the time and it turned out to be the abs sensor.
Yesterday when i was doing some maintenance i found out it was the metal-ring where the ABS-sensor is using for control that was broke :)
6 months later
6 months later
Lol yeah, well i found the problem earlier, but noone posted an answer ;)
  • 2 months later...
Hi Everyone,
For some time I've had an abs warning light up all the time. I checked the abs fault codes and got a 35. I was told this was a front left or rear right abs sensor fault. On checking further I ascertained that the problem was actually a front RIGHT wheel sensor which was open circuit. The normal static condition is approximately a 1500 Ohm loop. I changed this sensor today and the problem is cleared - the abs light is out and the abs system works fine under heavy braking. Hope this helps some of you guys out there.
thats code 36.
