98 Avensis Alarm
cea
My alarm sounds for no apparent reason and requires the Battery to be disconnected to silence the little devil. When the Battery is reconnected it behaves for about 7 ish hours then lots of sound again. Battery is 2 months old and everything else works as advertised. Have done the usual checks: 6 years of ownership and I've changed 1 bulb and 2 batteries so far so the car is normally a dream. 1998 1.8 GS 5 door RHD 77k miles. If I disconnect the unit under the osf headlight at the 4 pin connector will the lights still flash if the fault is elsewhere in the system. Anyone had the same? Cheers Carl
