Hi, I need a spare key for my lucida. The key I have does not appear to be coded or electronic in any way. How easy (and cheap) is it to get a copy?
Thanks in advance for answering a simple question :unsure:
Hi,it's very easy to get a key cut,from the key you have got.Only last week I got two spare keys cut for my daughters Lucida,cost £4.95,each,from any good key shop.Hope this helps..Lee
  • 2 months later...
Thanks, I will go and find a good key shop.
  • 1 year later...
if they use silca blanks then its probably blank code TOY30 I thought I'd say cus there are a few that look very much the same and with a worn key its easy to pick the rong blank, I now have 1 key that works just on the drivers door, 1 key that works on most doors and 1 that does all doors and starts the car.
You can also get these keys made "to code", if you email the number on the key to a key-cutter with one of these code key cutting machines. On my key I have a rather faded S1660 on the stem.
The advantage is, that this way you have a sort of fresh, factory-made key, rather than a copy of the worn original.
I got mine done via www.metrolocks.co.uk.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
